[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4769: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4770: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead
"Žaibo Rato" klubo forumas • Temos rodymas - Keletas pasiūlymų
Dabar yra 2022-06-30 04:50
Naujos temos kūrimas Ši tema užrakinta, jūs negalite redaguoti pranešimų arba atsakinėti į juos.  [ 263 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 14, 15, 16, 17, 18  Kitas
 Pranešimo tema: Re: Keletas pasiūlymų
StandartinėParašytas: 2010-12-29 21:40
Užsiregistravo: 2010-12-23 21:16
Pranešimai: 23
Miestas: Panevezys
sveiki (h) turiu pasiulyma moderams :) kitu klubu forumuose yra tokia naudinga temele apie nauju detaliu kainas, kokios firmos ji, kokia kaina, bei kur galima isigyti. man atrodo butu labai reikalinga tema ir sitam forume, ka manot? ta tema butu gerai, kad moderai laikytu atskirai nuo kitu prie svarbiu isskyre ir visada paredaguotu, kad butu tvarkingai isrykiuotos detales, kainos ir kt svarbi info pirmame pranesime, o forumieciai nustatyta tvarka pildytu savom zinutem tema, kurias paskui pakopinus, moderas perkeltu i pirmaja zinute, o nukopinta zinute istrintu. taip butu ir greitai galima surasti detale atitinkamai masinai ir neuzsiterstu per daug tema-butu viena vienintele zinute:) manau visi noretu pirktis detales pigiau ir kad nereiktu lakstyti per visas detaliu parduotuves. o gal net internete kokia detale pigiau, nei miesto parduotuveje ar turguje.
pvz fiat klubo tema
Opel Omega Caravan A 2,3D 1990m [ex]
Opel Omega Caravan B FL 2,5TD 2000m [2x ex]
Opel Insignia Sports Tourer 2CDTI 96kW 2009m automatic
Paskutinį kartą redagavo dziugesiukas 2010-12-29 21:46. Iš viso redaguota 1 kartą.
StandartinėParašytas: 2010-12-29 21:46
Forumo moderatorius
Užsiregistravo: 2009-08-19 12:37
Pranešimai: 1636
Miestas: Jurbarkas
yra temų apie tas detales ir dar konkrečiom mašinom pagal modelį ir kas kur pirko, kiek mokėjo, yra forume pardavėjų, kurie geresnėm kainom pardavinėja dalis, taip kad geriausias dalykas forume yra paieška (y) :-]
StandartinėParašytas: 2010-12-29 21:52
Pranešimai: 23
Miestas: Panevezys
hmm... ivedus i paieska "termostatas omega" ismete virs 500 pranesimu. ivedus "termostatas omega 2,5td" ismete vos keleta rezultatu. bet kainos ir kur rasti tarkim panevezio mieste as neradau informacijos. negi nebutu patogiau viena tema apie detaliu kaina ir tt?
StandartinėParašytas: 2010-12-29 21:55
Užsiregistravo: 2010-03-17 21:21
Pranešimai: 202
Yra ta tema. O kad tau termostato nerado tai dar nereiškia kad kažkas čia norėjo skelbt apie pirktą termostatą.
StandartinėParašytas: 2010-12-29 22:01
Pranešimai: 23
Miestas: Panevezys
nu tai tada prasyciau pasakyti kur tos temos ieskoti?:) kurioje skiltyje?
StandartinėParašytas: 2010-12-29 22:12
Pranešimai: 202
viewtopic.php?f=51&t=18915&p=268785&hilit=kainos#p268785
Va omegų tema
StandartinėParašytas: 2010-12-29 22:49
Pranešimai: 23
Miestas: Panevezys
va, dekui:) vis geriau nei nieko:D
StandartinėParašytas: 2011-01-12 19:31
kazin imanoma padaryt,naujokam apribojima,kad tarkim pirmas tris dienas negaletu kurt naujos temos,nes jau pradeda atsibost,tik uzsiregino iskart lempine tema
StandartinėParašytas: 2011-01-12 19:37
Administratorius
Užsiregistravo: 2006-10-31 12:08
Pranešimai: 5954
Miestas: Kėdainiai
Tas nieko nepakeis. Kam reikės labai - palauks ir vistiek kurs. Tokia jau mūsų Justai čia paskirtis, nukaršinti senolį ir nuvest į darželį pirmoką.
Girtas po kiemą mėgstu vaikščioti nuogas.
StandartinėParašytas: 2011-01-12 19:44
na negales kurt temos,tada ieskos info,ir ja ras,jei ne bus rades kazka panasaus bent as taip manau
StandartinėParašytas: 2011-01-12 22:54
Opelių maniakas(-ė)
Užsiregistravo: 2007-04-09 12:31
Pranešimai: 3385
Miestas: Vilnius/Biržai
šiaip mintis gera, nes tokiu atveju bus daugiau rašymo senose temose, ko pasekoje sumažės naujų temų kūrimas :D
Opel Omega B FL 3.2 v6 APD 2001
Opel Omega B FL 2.2DTI mechaninė 2001m. - last diesel in my life EX
Opel Omega B MV6 3.0 mechaninė 1996m. EX
Opel Rekord E1-2 (tuščia po kapotu) mechaninė 1982m.
StandartinėParašytas: 2011-01-12 23:55
Užsiregistravo: 2010-06-21 13:12
Pranešimai: 403
Miestas: North Wales/Vilnius
Kai užsiiminėjau forumais buvo tokie pluginai, dabar nežinau ar naujai platformai pritaikyta ;)
OVB DTI ' 98 74kw [EEJ 047] mėlynas universalas niauktais lungais su klyma 8]p
StandartinėParašytas: 2011-01-13 14:09
Užsiregistravo: 2007-08-21 20:44
Pranešimai: 886
Ar yra galimybė gauti kuriams nors klaipediečiui moderuoti būtent klaipėdos skilties moderavimo teises? lockinti, kurti temas iškeltas ir taip toliau? Nes realiai praktiškai iš visų miestu visitek po moderatorių bent vieną yra, o mūsų ramas pabėgo tai nebėra kaip. Nesinori per dar trečius asmenis kreiptis, kad moderuotų kaip ir mūsų sub-forumą.
StandartinėParašytas: 2011-01-13 14:16
Administratorius
Pranešimai: 5954
Miestas: Kėdainiai
Na čia reiktu adminui dėl šito rašyti. Tik kam to reikia? Trumpai brūkštelkit man kokios būtent ten tvarkos norit ir pažiūrėsiu.
StandartinėParašytas: 2011-01-14 14:44
Užsiregistravo: 2009-01-11 16:40
Pranešimai: 133
Miestas: Klaipeda
Siulyciau prikelti tema , kurioje anksciau publikavome savo masinu nuotraukas(su tema kokia nors, ar be temos) ir uz jas balsavo forumieciai.
Del prizu, manau jie nelabai reikalingi, galimas pirmos vietos ivertinimas kaip: Graziausios Omegos, vectros ir t.t.... savininkas. (trumpiau garbe arba ivertinimas, kaip teisingo automobilio turejimas :) )
Gal veliau atsirastu ir kokie prizai (bendru sutarimu)
konkursa rengti, karta i menesi ar reciau (jog dalyviu skaicius butu didesnis ir taip greitai neatsibostu si tema)
P.s gavus Virsininku pritarima, pirma konkursa organizuociau pats :)
Vectra 1.8l 16v sedanas :)
Vartotojai naršantys šį forumą: Registruotų vartotojų nėra ir 0 svečių
cron
