[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4769: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4770: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead
"Žaibo Rato" klubo forumas :: Temos rodymas - Pakalbekim apie GM
https://opel-klubas.com/forum/
Pakalbekim apie GM
https://opel-klubas.com/forum/viewtopic.php?f=12&t=30481
Puslapis 11
Autorius:  sunkus [ 2012-03-30 08:21 ]
Pranešimo tema:  Pakalbekim apie GM
vakar per meeta buvo siek tiek aptarta GM tema.
ir pasikalbeta, kad GM gaunasi eiline pjanke prie kokios balos
kas tikrai nedziugina.
juk prisigerti galima belenkada ir su belenkuo
palyginus GM su pvz BMWklubo GM, tai net pavydas ima
cia seilia pavarvint http://forumai.bmw-klubas.lt/viewtopic. ... 9&t=108557
todel pasiulymas pageidavimas butu toks: ar nepasidarius kokio renginio su kulturine programa,
kad paskui pasikojimuose nebutu vien gerem gerem gerem, tas nuluzo, tas prisigere tiek kad miegojo ne savo jurtoj
mastom :V
zinau kad klaviaturos riteriu cia atsiras daug, bet gerai butu kad kalbetu tie kas ne tik kalba, bet ir kazka padaro.
Autorius:  tereru [ 2012-03-30 09:31 ]
Pranešimo tema:  Re: Pakalbekim apie GM
(y)
Teisingas poziuris. Paantrinsiu - prisigerti galima ir per mazuosius meetus :)
manau tiesiog reiketu konkrecios veiklos plano per GM, gali tai buti ir kulturine programa, opelistu dragas, slalomas, kazkokios varzybos kuriu metu galima butu parodyti ismanyma apie opeli. Tiesiog manau butu galima pasivogti geriausio lietuvos vairuotojo konkurso plana ir pagal ji surengti geriausio opel vairuotojo konkursa per GM.
Butu testai, po ju tarkim slalomas, po to kazkokios uzduotys - na juk smagu butu suzinoti kas geriausias, tuo paciu ir azartas butu.
Tiesiog tokie pamastymai.
Autorius:  tdsas [ 2012-03-30 11:59 ]
Geriausio Lietuvos vairuotojo planas - labai gera mintis (y) šiaip nuolatinis galvos skausmas būna plotas - aikštelė, pakilimo takas ar pan. esant šitai aplinkybei galima viską aplipdyt aplink.
Autorius:  Flash [ 2012-03-31 21:12 ]
http://nemunoziedas.lt/Naujienos/Specia ... toklubams/
gal bus naudinga
Autorius:  neutrALUS [ 2012-03-31 21:46 ]
Neperžiūrėjau Kačergos pasiūlymo, bet esu skaitęs - kad lyg tik balandžio mėnesiui. Taip kad nelabai tinka.
Autorius:  teranis [ 2012-04-02 11:33 ]
ideja tikrai gera, bet tik vilnieciam tikrai gerai.. kokiem klaipedeiciam jau nelabai. nors aisku nori/gali dalyvauji, nenori/negali nedalyvauji.
Autorius:  FBI [ 2012-04-02 13:53 ]
o kuom klaipėdiečiams blogai? :) nelabai supratau :)
Autorius:  filks [ 2012-04-02 14:16 ]
sunkus labai teisingai parase, apie tuos gerimus (y)
nu o kad visiem butu panasus atstumas(didelis) tai darom kokioj lenkijos vidury :D
Autorius:  sunkus [ 2012-04-02 15:34 ]
baikit inkst del tos vietos, kas nori tas ir i paprasta meeta 130km nuvaziuoja, o karta per metus, kad nuvaziuosit iki GM 200km nei pervargsit nei nubiednesit.
Autorius:  tdsas [ 2012-04-02 15:46 ]
aš po pirmo sudalyvavimo GM padariau išvadą, kad kur bebūtų GM, aš jame dalyvausiu*. Lietuvos atstumai yra pakankamai juokingi, kad dėl to neatvykt.
*aišku jei nebus kokių force majeure, tokių kaip vestuvės ar pan :D
Autorius:  tereru [ 2012-04-02 16:07 ]
Kam idomu ir kas nores atvaziuos bet kur :) Del manes gali meetas ir Klaipedoje buti, koks skirtumas. Jis viena karta metuose. Jei nori pamatyti bendramincius sesi ir atvaziuosi.
Todel nemanau kad verta derintis prie zmoniu, nes to nepavyks padaryti vistiek - vienam per toli, kitam laikas blogas, treciam programa netiks :)
Gana inkšt visiems ir derinam programa, veikla o ne kiek kam vaziuot :)
Autorius:  FBI [ 2012-04-02 16:10 ]
eilę metų iš klaipėdos susikoperavę chebra atvažiuodavo, ar viena mašina, ar dvi, bet atvažiuodavo, kartais ramas ir vienas atvarydavo, ir nieko, viskas ok būdavo. tai manau mažiausia čia bėda tie atstumai.
Kadangi čia kalbos ir pasiūlymai apie GM, tai kažkada senais laikais buvau pasakojęs tai, patiko Voyager klubo įdėja GM kasmetiniams. pas juos kiekvienais metais GM rengia vis kitas didmiestis, todėl visiems vienodos sąlygos gaunasi kilometražais, ir pas juos nebūna tokių dalykų kaip važiuoju tik tais metais kai šalia vyksta, ten chebra su žmonom, vaikais suvažiuoja. Kitas dalykas, tas variantas kad GM rengia vis kitas didmiestis, tai šiek tiek apjungt galėtų visą mūsų bendruomenę, aišku nepriversi kažko kad surengtų jei nebus noro ir iniciatyvos, bet bandyti galima, tiesiog reikia savanorių iš kiekvieno miesto, kurie galėtų prisiimti kažkiek atsakomybės, bendrauti su kitų miestų atstovais, tartis ko reikia, kur reikia, kiek reikia, tik taip manau galima bus surengti tai ko nori visi o ne penktadalis.
Puslapis 11 Visos datos yra UTC + 2 valandos [ DST ]
Powered by phpBB® Forum Software © phpBB Group
http://www.phpbb.com/
